FB Twitter Instagram
Orion Delta Ball-Cup Delta Arm Kit
  • Sale
  • Regular price $39.00
  • SKU: 70864
These Orion Delta ball cup injection molded arms are similar to the RostockMAX v2 & v3 arms. They are designed to work flawlessly with our injection molded carriages. Spring loaded tension eliminates any backlash and also makes assembly a 'snap', literally!  These arms are only appx. 1mm longer than the stock arms, so only a slight modification in firmware is needed to set the values up for these arms
You must have the injection molded carriages in order to use these arms.  They have the features to attach this item..  If you DON'T have injection molded carriages, you will need them to install these arms.  Click HERE to order the injection molded carriages.
Includes the following parts in each kit:
  • 6 - 179mm Ball Joint Arms (molded)
  • 6 - Ball Joints for the injection molded carriages and platforms (molded)
  • 3 - Hotend Platform Spacers (aluminum)
  • 6 - Tension Springs for ball joint arms (molded)
  • 3 - 6-32 x 1 3/4" Phillips pan head stainless screws
  • 3 - 6-32 Nylon stainless lock nut
  • 6 - #4 x 3/8" stainless sheet metal screws
  • 6 - #4 SAE stainless flat washer
  • 1 - Ball Joint style platform (molded)
  • 1 - Small zip tie
Assembly Required, Check out the How-To Assembly Guide
