FB Twitter Instagram
FabLam™ SET Spring Steel PEI & Magnetic Sheet 310mm Diameter
  • Sale
  • Regular price $96.00
  • SKU: 26625
FabLam™ Set
PEI Powder Coated Spring Steel & Magnetic Sheet with Adhesive.
SeeMeCNC high quality PEI Powder Coated Spring Steel Bed Plate.  Both sides are PEI Powder Coated with texturing.
The PEI build surface does not require preparation before printing.  The 3D print is easily released by flexing the FabLam Flex™ spring steel plate.
The high temperature magnetic sheet is rated up to 130C. The magnetic sheet has adhesive on one side. Designed to stick to our 310mm borosilicate glass plate (sold separately). You may clean and stick to your existing glass plate, however keep in mind the bond is permanent.
No modifications. Our FabLam design requires no changes to your printer.
Includes:
  • One double sided PEI Powder Coated/Textured build plate
  • One Magnetic Sheet with adhesive one side
  • Warning label stickers for printer enclosure
Warning label stickers for printer enclosure (This product covers important safety information on the build surface, requiring the warning sticker to be installed on the front-top side of the enclosure to ensure safe use of the printer.)
Compatibility:
Replacement parts and reference information.
  • PLA, PETG, Carbon Fiber PETG, ABS, TPU, PVA
  • Designed for SeeMeCNC FabLam™ build platesBuild plates without a magnet found here
  • SeeMeCNC 3D Printers: Rostock MAX v1, v2, v3, v3.2, v4, Artemis, BOSSdelta 300
Installation:
  1. Clean existing glass build plate
  2. Peel adhesive protective paper 1/2 way off magnetic sheet
  3. !! Very Sticky - Carefully center magnet on glass, being careful NOT to trap air, then slowly start sticking from one side to the other
  4. Peel protective backing while adhering across the glass until finished
  5. Install on printer
  6. Slap on the spring steel FabLam™ - and your ready
Tips:
Not many tips needed, this works great!
  • occasionally clean with alcohol
  • sometimes, certain plastic may seem to loose adhesion after many printer, in this case gently use a green (not metal) abrasive pad to clean off the surface. Will last a very long time before this is needed again
Shipping Magnets
  • Magnetic sheet sold only with FabLam spring steel plate due to shipping regulations.
  • We do not sell magnetic sheets separately
