Shipping lead time ~2 weeks (:
Price 1/2M and 1M tall machines include professional packing and door to door delivery in the 48 United States. We do not ship this printer internationally.
SeeMeCNC large format 3D printers will meet your business needs for commercial 3D printing through price, performance, and reliability. Large 20.5" (520mm) diameter AC powered heated bed.
The BOSSdelta™ features our eSlide™ linear motion system. The eSlide™ linear motion solution is engineered and manufactured by SeeMeCNC. Our linear motion design started in 2012. We designed our first high accuracy, lower cost linear motion system for the RostockMAX series 3D printers. We have years of proven performance, low maintenance, high reliability, and high accuracy, of our eSlide™ motion system. The design has commercial-use in mind. Our unique wire cable to belt drive system provides accurate positioning of the hotend platform even on extend Z height models.
The aluminum hotend platform uses the SE300 hotend assembly. The SE300 hotend is designed for 280C maximum operating temperature. The SE300 hotend contains an integrated strain gauge sensor for providing reliable and accurate automatic probing and calibration. During probing, the nozzle taps the build surface for the highest accuracy even after a nozzle change. The carbon fiber arms rigidly connect the hotend platform to the carriage slides. The print surface (bed) is borosilicate glass and can easily handles 100C temperatures maintained by the 800W industrial heater. The glass build plate heats from room temperature to 60C in about 4 minutes and 100+C in approximately 12 minutes.
The 7 inch touchscreen controller is removable so the printer can be operated at the print bed level. The is useful for custom setups or making adjustments during operation without having to reach for the controls.
The BOSSdelta™ 500 features a Duet 32 bit main control board with Ethernet connection for your network. Connect to internal networks using a standard network cable. The printer console screen will display the assigned IP address. From a computer web browser on your network, simply enter the IP address of the printer to display the web control interface for the printer. Optionally, it is not necessary to connect to any network. The printer can be operated by using a quality SD card 32Gb or smaller inserted into the front of the printer.
Quick Start for SeeMeCNC Printers
We have put together a Quick Start page found here (SUPPORT > Quick Start). The information will help you properly begin using your SeeMeCNC printer. You will learn how to quickly setup the recommended and supported slicing software and then successfully begin your first print.
Visit our Quick Start page now by clicking the link above and setup the slicing software today! You can do this before purchasing a printer. Simply follow our guide!
The BOSSdelta™ 500 series
Specifications
- Print area 1/2 Meter Diameter by 1/2 Meter Tall
- Filament Runout Switch
- Actual print area is 500mm D x 580mm H center (500mm H edge)
- Now with the SE300 Hotend (After March 2021)
- EZR Struder Filament Drives
- Dual Extrusion Standard
- 32 bit Control with Ethernet Network Connectivity
- eSlide™ SeeMeCNC Linear Motion System
- Power Requirements 120VAC Single Phase 10A
- 800W AC Heated Bed with anodized aluminum heat spreader
- Overall Machine Dimensions 31.5" Wide x 29" Deep x 55" Tall
- One Year Warranty
- LTL Freight Shipping Included
- Printable Area is 1/2 Meter Diameter by 1 Meter Tall
- Overall Machine Dimensions 31.5" Wide x 29" Deep x 75" Tall
- All other specifications same as above
- Printable Area is 1/2 Meter Diameter by 2.1 Meter Tall
- Overall Machine Dimensions 31.5" Wide x 29" Deep x 118" Tall
- Single Extrusion
- We recommend securing this machine to the floor or a wall or post
- LTL Freight shipping additional (not included)
