FB Twitter Instagram
SeeMeFPV Power Pack Motor and ESC Combo
  • Sale
  • Regular price $80.00
  • SKU: 26898
  • instock
This power pack comes with 4 of our SeeMeFPV motors, 4 of our 20 amp BLHeli ESC's and 1 pair of XT60 Connectors.  Everything you need to power your next FPV racing multi rotor in a quadcopter configuration.  Choose from our 2204-2300kv or our 1806-2300kv motors depending on your frame and prop size.
Motor Specs -
  • 200mm motor wire leads
  • 2204 motors feature M3 motor mount holes - 16mm x 19mm pattern
  • 1806 motors feature M2 motor mount holes - 14mm x 16mm pattern
  • M2 prop adapter mounting holes - 9mm 4 hole pattern
  • Comes with M2 x 5mm and M3 x 5mm hardware
  • Includes 3 2mm bullet connectors
  • Includes standard right hand 5mm prop adapter
ESC Specs -
  • 20 Amp continuous - 30 Amp intermittent
  • OPTO - (No BEC Circuit for lightweight)
  • SN20 w/BLHeLi 14+ pre-flashed with DL enabled
