A dual extrusion adapters for SeeMeCNC single hotend / nozzle printing.
Tested and working with our slicing profiles and settings. You will need to figure out your settings for your configuration.
With our Dual Filament Feed Adapters you can feed and print in 2 different materials or colors with one single nozzle. The adapters are injection molded from clear ABS so you can see filament switching.
Dual extrusion with two colors lets you create more colorful prints. Add accent colors to your models and colorize your text or other features.
Dual extrusion of different materials allows you to print models with flexible features AND rigid features in one model for instance. You can also print your model with one material and take advantage of some of the dissolveable support materials now available for ABS, PLA and other materials.
These adapters are made for use with 1.75mm filament only. They come with 4mm PTC cartridge fittings and our PTC lanyards to prevent backlash and lock the fittings on to the PTFE tubing.
Included:
- PTC Lanyards locking clips
- Dual Y Adapter Assembly
No other parts are included. This is the Y Adapter piece only. PTFE Bowden tube sold separately.
Compatibility
Current Model Instructions - Click Here - STEP 10
If purchased before July 2018 - Click Here
