FB Twitter Instagram
RostockMAX v4 ARP™ Partial Assembled Kit
  • Sale
  • Regular price $1,499.00
  • SKU: 59099
  • Will be in stock after
Estimated Shipping End of January 2018
The RostockMAX v4™ Desktop 3D printer is a full featured almost ready to print (ARP™) 3D printer. The RostockMAX v4 requires an estimated 5 to 6 hours of assembly. It features a 32 bit controller with WiFi, a huge build volume, auto leveling, and more.
The RostockMAX v4 features an all new rigid metal frame construction and 350W AC heated bed with aluminum heat spreader. Easy to achieve 120C maximum bed temperature. The motion system uses our original Cheapskate carriage design shown at the World Make Faire in 2012.  The RostockMAX v4 moves nearly twice as fast* during rapid moves which is made possible by the metal rigid frame and 32 bit motion controller. Auto leveling and WiFi control.
The Almost-Ready-to-Print (ARP) kit is a partially factory assembled machine. We do all the tricky stuff and leave the final assembly up to you. Bolt together major sub-assembly components, plug in wires, and connect. The ARP machines save you  money on shipping. Also available fully assembled.
So which new printer is right for you?  Compared to a RostockMAX v3, the metal frame RostockMAX v4  produces better prints.  The Artemis will produce the best prints.
STANDARD Features:
  • 32 bit DUET WiFi control board
  • Auto Leveling
  • WiFi Control
  • Cheapskate injection molded linear motion
  • AC 350W Heated Bed
  • Aluminum Heat Spreader
  • NEW Hotend (not pictured)
  • Triple part cooling blowers (GCODE Controlled)
  • 0.9 degree NEMA 17 Stepper Motors
  • 16 Tooth Pulleys
  • Powder-Coated Sheet Metal Coves and Enclosure
  • Sturdy 1x1 T-Slot Extrusion Frame
  • 310mm Borosilicate Glass Build Plate
  • Injection Molded Plastic Components
OPTIONAL Features Sold Separately:
  • Dual Extrusion optional
  • Carbon Fiber Arm Set optional
  • 5" Touch Screen Display
Printer Specs:
  • 290mm D x 450mm H (PEAK) Maximum Printable X/Y Area
  • 290mm D x 420mm H (Perimeter) Maximum Printable X/Y Area
  • .005mm MAX XY Resolution
  • Minimum Recommended Layer Height w/.5mm nozzle of .1mm
  • Maximum Recommended Layer Height w/.5mm nozzle of .4mm
  • Maximum Recommended Printing Speed @.2mm Layer Height 100mm/s
  • Maximum Usable Printing Speed @.2mm Layer Height 150mm/s
  • Filament: 1.75mm PLA, ABS, PETG, HIPS, NinjaFlex SemiFlex
  • Max Heated Bed Temp 120C
  • Max Travel Speed 400mm/s*
  • Hotend Temp 280C
  • Power Requirements 110VAC @ 350 watts (not 220V compatible)
  • Overall Printer Weight: 46lbs
  • Overall Printer Footprint: 19in Depth x 21in Width
  • Overall Printer Height: 40in
* moves about twice as fast compared to our world leading delta, the RostockMAX v3
PLEASE NOTE: The hotend in the photo's will be different. An all new triple blower design will ship with these units.  :)  New circuit boards did not arrive in time for photos.
