visit us at solidworks world 2017 Feb 5-8 in Los Angeles California
Menu
Cart 0
ROSTOCK MAX™ v2 Desktop 3D Printer RTP™
  • $1,89900
SeeMeCNC P/N: - UPC:
discontinued  search  v3
Getting started guide for setting your new Factory Assembled Rostock Max v2
No time to build, but want your own Rostock MAX v2 3D Printer?  No problem!  We are currently offering a limited number of factory assembled Rostock MAX v2's - assembled by the same team that builds our Orion Delta Ready To Print models.
Shipping is only available to the lower 48 states via freight so make sure a semi truck can deliver to your shipping address listed on your order.  We're sorry but we CANNOT ship internationally at this time.
FROM ITS HUGE BUILD VOLUME TO THE AMAZING COMMUNITY OF BUILDERS, YOU'LL QUICKLY LEARN WHY SO MANY PEOPLE HAVE CHOSEN THE ROSTOCK MAX V2 AS THEIR GO-TO MACHINE.  The rostock max v2 is for everyone - FIRST-TIME BUILDERS to SEASONED ENTHUSIASTS - with EVERYTHING YOU NEED TO GET INVOLVED IN 3D PRINTING.  with LASERCUT FRAMEWORK and HIGH-QUALITY INJECTION MOLDED PARTS, IT'S BUILT TO LAST TOO.
• Redesigned hot-end platform and Delta arms and mounts.
• Top-mounted spool holder shortens the length between the EZStruder and spool, minimizing machine footprint.
• New base enclosures protect your electronics from dirt/dust, for a clean, attractive appearance.
• New top design provides more rigidity for better prints, easier assembly and calibration.
THESE IMPROVEMENTS ARE ADDED TO THE ALREADY IMPRESSIVE LIST OF STANDARD COMPONENTS AND FEATURES:
• Nearly 1300 cubic inches of build volume (10.5+" Diameter by 15+" height)
• Made in the USA - high quality, laser cut, injection molded and CNC machined parts manufactured by SeeMeCNC
• EZ Struder and hot-end set up for 1.75mm filament
• Standard .5mm nozzle - easily changeable to other available sizes
• High-torque NEMA 17 stepper motors
• ATX power supply for safety and easy upgrades
• RAMBo by UltiMachine electronics - the best available 3D printer controller
• Tinker-friendly electronics and hardware - many extra places to add your own mods to both
• Borosilicate glass build plate for safety and precision
Rostock MAX v2 Specifications
Overall Printer Size
18" Diameter
Overall Printer Height
48" tall w/spool mounted
Overall Printer Weight
25 Pounds
Power Requirements
100-240 AC 350 Watts (Selectable on power supply input)
Shipping Dimensions
32" X 19" X 6" Box weighing 42 pounds
 Build Area
Maximum Printable X/Y Area
11" Diameter (280mm)
Maximum Printable Square Size
7 3/4" (197mm)
Maximum Printable Z Height
14 3/4" (375mm)
 Printing Specifications
Max X/Y Resolution
.1mm
Max Z Resolution
.0125mm
Avg. Print Speed
30-60mm/s
Max Movement Speed
300mm/s
Max Hotend Temperature
245c
Max Heated Bed Temperature
100c
Part Cooling Fan
Included (G Code Controlled)
Customer Reviews
Be the first to review this! Have one? Write your own review!
