Proto Pasta High Temp Annealable Silver Smoke 1.75mm PLA 3D Printer Filament .5kg Spool
  • Sale
  • Regular price $35.00
  • SKU: 50207
  • 5 available
Proto-pasta's High Temp PLA v2.0  is everything the original version should have been. This new formulation is higher performing, more obviously heat treatable, and lower cost. This tough PLA prints with ease but has a potential Heat Deflection Temperature (HDT) of as much as 140C (285F) depending on post-processing. This means parts retain more stiffness and form at higher temperatures (no warping on your sunny car dashboard). For maximum performance, your prints should be heat treated (i.e. crystallized) in an oven until you see a change from translucent to opaque. Yes, there is an obvious visual change indicating the improved performance!  They had good luck in a lab oven at 110C (230F) for an hour or less.  They also recommend leaving the supports on your parts, placing them on a non-radiating surface (like glass, ceramic, or composite), and letting them cool in the oven to minimize distortion. Parts can be baked at a lower temperature (though must be above 60C for any change to occur) for a longer time with less risk of unwanted deformation.
  • 500g 8" diameter spool only
No abrasive fillers so expect normal wear with standard nozzles.
