visit us at solidworks world 2017 Feb 5-8 in Los Angeles California
Menu
Cart 0
1.75mm Protoplant Protopasta Conductive PLA 3D Printer Filament
Proto Pasta Conductive 1.75mm PLA 3D Printer Filament 0.5kg Spool
  • $4800
SeeMeCNC P/N: - UPC:
ELECTRIFY YOUR 3D PRINTS!
Have you ever wanted to create something with your 3D printer that includes electronics? Maybe an LED, touch sensor, or some other genius invention to solve the world’s problems? Then Proto-pasta Conductive PLA is the perfect material for you!
  • Prints with standard PLA settings - no heated bed or fancy hardware required
  • Great for simple circuitry and interactive projects
  • Comes in 1.75mm 500g spools
HOW CONDUCTIVE IS IT?
  • Volume resistivity of molded resin (not 3D Printed): 15 ohm-cm
  • Volume resistivity of 3D printed parts perpendicular to layers: 30 ohm-cm
  • Volume resistivity of 3D printed parts through layers (along Z axis): 115 ohm-cm
We Also Recommend
