FB Twitter Instagram
*** rev7 *** ONYX Heated Bed rev 7 - discontinued EOL
  • Sale
  • Regular price $69.00
  • SKU: ONYXREV7
SOLD OUT  EOL
End of Life.
FOR ROSTOCKMAX v2 ONLY
THESE DO NOT FIT ON v3 MACHINES
This heated bed IS NOT used on the RostockMAX v3. The RostockMAX v3 and RostockMAX v3.2 use rev10.
Features:
  • rev7 = revision 7
  • 310mm Overall diameter
  • 3mm thick
  • 280mm Heated Area
  • Designed for 12V operation, can be used with 24v with limiting the PWM signal etc...
  • 12 3mm diameter mounting holes spaced on a 300mm diameter pattern
  • Approximately 1.1 Ohms resistance @ room tepmerature (70f)
  • Thermistor location offset from the center of the bed for more average readings
  • Pads for power LED and resistor to indicate bed power
  • Mounting hardware included as well as LED and resistor for power indication
  • Melamine laminated standoff/insulator
  • Includes 100k Thermistor
