A quality spring steel plate made for SeeMeCNC 3D Printers. These flex plates need a magnetic build plate to work properly.
Includes:
- 310mm Diameter x ~0.4mm thick steel plate
- Replacement warning labels
Compatibility:
- Artemis 300 *magnetic plate needed
- RostockMAX (all varieties) *magnetic plate needed
- PEI Build Surface Stickers
Setup for SeeMeCNC Duet controlled Deltas
- Magnetic plate needed for this product
- clamp FabLam Flex on top of glass
- modify config.g probe offset to -0.5 (see following line from config.g)
- G31 P100 X0 Y0 Z-0.5 ; Probe trigger and offset values for FabLam Flex Spring
- follow this guide for Duet bed mapping reset
